53 WD no spark |
Post Reply |
Brian L
Bronze Level Joined: 29 Jun 2019 Location: Norfolk Points: 12 |
Posted: 22 Feb 2020 at 2:21pm |
I sold My 53 Wd parts Tractor it was stuck in 1st Gear got that fixed.Used to be a Fork Lift.Tryed to start but not spark.Put in new points and Condensor still nothing changed the condensor twice.I have power to the points but no spark.Could i have a bad ground to the base plate on the Distributor.Any thoughts Please
Bill Long
Orange Level Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Just some thoughts from an old man. if Mag Think of a roto, cap, and coil.
Good Luck! Bill Long
MACK
Mag or distributor? MACK
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2226 |
Kinda sounds like one of my C's right now LOL!! --- I even took the guts from a running tractor and put in it. ---Juice across the points, BUT none to the plugs. Still nothing with the running tractor parts installed in this one either. --- Kinda a head scratcher!
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 613 |
When you roll it over with the cap and rotor off do you see a spark when the points open? Did you try a different rotor? Had one where the tab was bad and not contacting the cap. Is the button in the center of the cap in good condition? What about the coil. Did you take the wire from the center off the cap and hold it a 1/4 inch from a ground and roll it over to see if the coil is sending the spark out to the cap?
ac fleet
The whole cap/wires/rotor/condenser/points/plugs/coil/etc were used, still no fire at plugs.Would like to use this one this spring.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8061 |
To be sure the points are working,pull coil wire out of distributor,remove cap and dust cover,turn engine so points are closed but can be broke open by twisting rotor moving the advance. Ignition on,hold coil wire 1/4 in from block and twist rotor. Points should have slight spark and blue spark jumping to block from coil wire. Good spark will jump 1/2in. This assumes you have points set so they close and open correct amount.
MACK
Terminal going through distributor could be grounded. MACK
Post Reply | |
