53 plow
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: 53 plow
    Posted: 23 Feb 2019 at 2:08pm
Is it possible to make a 1 bottom plow out 3 bottom 53 plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2019 at 4:08pm
Yes, just remover the two rear beams and some of the framework.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2019 at 8:24pm
Thanks Paul B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2019 at 9:54pm
If the plow parts book linked over in the Knowledge Forum at Plows 101 is still available you can look up the 51 and 53 plow frames and compare their parts.
The simplest conversion would be to take off the two plow bottoms and shanks to the rear and use only the front. The top link may require more frame to the rear than would be left by taking off plow frame parts behind the front bottom.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 3:15pm
Thank you Harold J
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 3:17pm
THANKS JAROLD J SORRY ABOUT THAT.
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 4:13pm
You may have to shorten the beaming part......good advice above to find some pictures....or change to smaller bottoms for easier pulling...
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 6:14pm
Gerald J, lol!!! Harold, Jarold, he's good natured.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2019 at 7:36pm
Personally,I would take the front 2 bottoms off and move the rear bottom to the front so you would have the long landslide and skid for depth control. JMHO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2019 at 10:01am
Moving the whole rear bottom to the front might work but the landside on the bottom of the plow shank might be easier to move to the front bottom than to move the whole rear bottom and stud up front.
Gerald J.
