52ca reserve fuel tank
PTOman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PTOman Quote  Post ReplyReply Direct Link To This Post Topic: 52ca reserve fuel tank
    Posted: 02 Aug 2024 at 10:35pm
in the manual it shows a reserve fuel tank for the 52 CA did Allis Chalmers put these on all years of CA I don't even see a location where that might be fitted thank you
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 7:16am
Are you referring to the auxiliary tank that's 1 gallon? If so, that is only on tractors that were set up for burning low grade fuels. It was for gasoline and you would use it to start the engine, then switch over to distillate after warmed up (or whatever low grade fuel you had in the main tank).
There probably aren't very many CAs out there as low grade fuels were falling out of favor by the time the CA was being built.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 8:01am
gee, I consider all gas with ethanol in it, 'low grade' !! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PTOman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 10:23am
I understand that distillate is a little lower grade than kerosene however it amazes me that all our jet aircraft are flying on kerosene goes to show you that older is better
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 10:29am
It runs on distillate yes, but quite a bit lower horsepower for a spark ignition engine and way more pollution :(  Even gasoline in the early 50s was only 70 octane so only a little more HP.
1952 CA13092
This page was generated in 0.083 seconds.
