52 WD Shifter
Tim in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Topic: 52 WD Shifter
    Posted: 05 Apr 2011 at 6:44pm
I've been working on the WD trying to get it ready for spring, which hasen't hit up here yet.  I've noticed since I got it that it shifts hard between gears, and just barely engages into 4th gear.  Any ideas why this is happening?  Gear lube was changed out last fall.
        Thanks, Tim
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 7:53pm
Does the clutch feel like it's working properly or is the shifter just hard to move?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 9:25pm
It runs ok, no noise in the gears, just hard to move the shift lever.  I adjusted the clutch last fall, there was NO space between the arms and the throw out bearing, that didn't do any good.  How much clearance is there supposed to be between the throw out and the pressure plate arms?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 9:45pm
The book says 1/4" clearance between the bearing and the levers which will produce 1/2"-1" on the pedal at the frame rail.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 10:29pm
you better hurry up....spring is bouts here!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 12:06am
Spring?  What's spring, it snowed up here Sunday and Monday.  About ready to move south.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:40am
YA!!  Youse guys down south are talking about cutting grass and all kinds of other obnoxious stuff.  We're still getting snow (although it is raining right now) and it is highs in the 50's.  Ship some of that Southern winds up this way will ya!!
This page was generated in 0.111 seconds.
