516
Brock58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brock58 Quote  Post ReplyReply Direct Link To This Post Topic: 516
    Posted: 13 Jul 2025 at 8:58pm
Has anyone put a 516 in a d21 curious as to what all had to be done for it to fit
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2025 at 11:47am
The only contribution I can make is to state the rear main seal and wear sleeve seem to be common with the 426 .... that means flywheel issue is not unsurmountable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2025 at 5:47pm
I imagine Mark Gettinger has done one or more. For a puller, you'd have to have a steel flywheel made anyway, so that's easy. The starter to flywheel/ring gear dimension and then maybe rework the D-21 engine backplate to fit the 516 block would solve that issue, and the bolting up to the bell housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2025 at 6:45pm
Isnt the 516 alot heavier than a 426??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 7:17am
A basic 426 intercooled 220 HP engine weighs 1465 lbs.  A basic 516 intercooled 270 HP engine weighs 2360 lbs. The 516 family engine (also made in a 4 cylinder 344 cube version) was a carry over from the Buda company days, probably a mid/late 1940's initial design. The 426 was an all new modern Allis-Chalmers design from the early 1960's (as also was the 301/200 family). It is a larger heavier engine design per cubic inches of displacement. If it compared to a 426 design for weight, it should be about 1800 lbs, not 2360 lbs.  The 516's physical size and weight actually compares to a Cummins L-10 (600 cubes) or M-11 (660 cubes) which weigh 2100-2200 lbs.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2025 at 9:08am
  Two from Ohio I believe is the correct state, they both have naughty names, do quite well.
4BA_D-17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4BA_D-17 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2025 at 5:42am
There are actually three from Ohio that have 516’s in them. Two are orange and the other is industrial yellow. They pull in a class called classic super stock. There is actually another one being built right now that was a 3 charger super with a 426 in it.
Barnyardpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 44 minutes ago at 12:09pm
On a somewhat related note, I stumbled across a 516 locally that I was considering purchasing to build a pulling motor. I’m fairly new to the Allis world so I was wondering, what model tractor would best hold up to the power?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 25 minutes ago at 12:28pm
Pulling forum, so might not apply? But here’s a link to Peterson’s N7 8050.
https://www.allischalmers.com/forum/8050-n7-engine-swap_topic160189_page4.html
This page was generated in 0.035 seconds.
