516 |
Brock58
Topic: 516Posted: 13 Jul 2025 at 8:58pm |
Has anyone put a 516 in a d21 curious as to what all had to be done for it to fit
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 15 Jul 2025 at 11:47am |
The only contribution I can make is to state the rear main seal and wear sleeve seem to be common with the 426 .... that means flywheel issue is not unsurmountable.
Posted: 15 Jul 2025 at 5:47pm |
I imagine Mark Gettinger has done one or more. For a puller, you'd have to have a steel flywheel made anyway, so that's easy. The starter to flywheel/ring gear dimension and then maybe rework the D-21 engine backplate to fit the 516 block would solve that issue, and the bolting up to the bell housing.
DougG
Posted: 15 Jul 2025 at 6:45pm |
Isnt the 516 alot heavier than a 426??
Posted: 16 Jul 2025 at 7:17am |
A basic 426 intercooled 220 HP engine weighs 1465 lbs. A basic 516 intercooled 270 HP engine weighs 2360 lbs. The 516 family engine (also made in a 4 cylinder 344 cube version) was a carry over from the Buda company days, probably a mid/late 1940's initial design. The 426 was an all new modern Allis-Chalmers design from the early 1960's (as also was the 301/200 family). It is a larger heavier engine design per cubic inches of displacement. If it compared to a 426 design for weight, it should be about 1800 lbs, not 2360 lbs. The 516's physical size and weight actually compares to a Cummins L-10 (600 cubes) or M-11 (660 cubes) which weigh 2100-2200 lbs.
NEVER green
Posted: 16 Jul 2025 at 9:08am |
Two from Ohio I believe is the correct state, they both have naughty names, do quite well.
4BA_D-17
Joined: 02 Oct 2011 Location: Burbank, OH Points: 50 |
Posted: 11 Oct 2025 at 5:42am |
There are actually three from Ohio that have 516’s in them. Two are orange and the other is industrial yellow. They pull in a class called classic super stock. There is actually another one being built right now that was a 3 charger super with a 426 in it.
