51 wd points
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: 51 wd points
    Posted: 13 Feb 2019 at 6:32pm
What should the gap be on the points on my wd?
You set the gap when its on the corner or lobe correct, and then they should close when they are on the flat part?
Thanks
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2019 at 7:38pm
Yes your method is correct. Point gap is .020".  Spark plug gap if you are checking is .028 to .032" as per owner's manual for WD45 tractor. I generally set mine at .025" Should be same spec for WD.
This page was generated in 0.168 seconds.
