5030 fuel injection pump again
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: 5030 fuel injection pump again
    Posted: 20 Oct 2023 at 9:37am
I would appreciate it if someone could post a picture of where to drain oil, check level and add oil  for the lube oil in the  injection pump on the 5030. Thanks
Dean(IA)
I M Fedup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I M Fedup Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2023 at 9:56am
It doesn't appear that anyone is all that interested in helping you out here. Why now post a few photos of your pump from different angles. Maybe someone will offer some suggestions based on what the photos show.
Sometimes the drain, level, and fill points are glaringly evident, sometimes not so much. I've seen pumps where the only way to do it was loosen the back cover to drain the oil, then guess at the level when adding it back.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2023 at 7:28am
Do you have a manual for your 5030?  It does show the location in manual.    From a 5020 perspective the fill plug is on top of the pump and has something that looks like a breather cap that unscrews.  The drain and check plugs are towards the bottom and close together.   you can use a wrench or screwdriver on either of them.  The check plug is up and to the left of the drain plug.  I will try to get a picture later, but have been pretty busy of late.
