5020 Starting problem
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Topic: 5020 Starting problem
    Posted: 06 Apr 2010 at 7:57pm
electrical problems are not my specialty so any help will appreciated. tractor will not always start with the key so I need to use a screwdriver at the solenoid to start. seems to be worse in cold weather thanks. Eric
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 9:00pm
check your safety start button.  it may be out of adjustment or  by pass it  to see if thats the problem
160 CA 920diesel 5020 HD-3
MBwcenll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 9:16pm
On the one I had, a wire was always coming loose under the dash.  Right hand side.  Just enough room to reach up and fix.  Been too long to remember what it attached too.  Any way it was just eaiser to jump the solenoid.  Also good way to theif proof.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 11:39am
thanks guys, the safety switch was already bypassed when I purchased it and I don't mind the screwdriver method but my lovely wife does not
