5020 3 point |
Author | ||
EricPA ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Watsontown,PA. Points: 2578 |
![]() ![]() ![]() ![]() ![]() Posted: 14 May 2018 at 6:03pm |
Need help, recently when I started my tractor the 3 point arms raised rapidly all the way to the top even though the lever was in the down position and now they wont budge. prior to that when I started it the would raise slowly to where the lever was set at with a little whining as they rose.
Thanks, Eric
Life is tough,but it's tougher when you're stupid. - John Wayne
Sponsored Links | ||
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54323 |
Lotsa japanese built tractors have a control valve, just under the seat, that controls speed of descent of the lift arms. If you see a knob, under the seat, I'd check that valve, first. could have a blockage...
Did that, turned it all the way both ways and still nothing. |
Might haveta take it off, and inspect the innards...
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3285 |
The control valve you guys are talking about just controls speed of lowering. If lever is all the way down, control valve should not cause arms to lift.
Does your tractor have draft control? That may cause it to lift if not working properly. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
There was a linkage broken under the cover so a local machine shop repaired the linkage but now the arms will move by hand but not hydraulically
