5015 Screen
Mudflap View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mudflap Quote  Post ReplyReply Direct Link To This Post Topic: 5015 Screen
    Posted: 20 Feb 2024 at 9:34am
New here looking help.
I have a 5015 that I need to change transmission fluid on. I have read there is a screen that needs to be cleaned. Looked at parts catalog and can' find it. Where is it?
Thanks
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 12:46pm
Remove oil filter housing to  the case , use a bore scope if u can't see straight in to see if it is a screen .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mudflap Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 6:10pm
thanks
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 7:59pm
probley behind the  suction pipe  inside the trans were the pipe bolts on to the trans
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2024 at 8:47pm
The oil filter housing bolts to case , not the suction pipe .
 Remover filter mounting housing and # 20 ,   if you  believe there is a screen.
Edited by Fred in Pa - 21 Feb 2024 at 8:53pm
Jasonw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonw Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 6:27am
The 5020 and 5030 models have a suction screen that can be cleaned but the 5015 just has the spin on filter element. Agco part number 72100796.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mudflap Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 8:00am
Thanks
