500 series loader cylinder repair.
N6PETE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N6PETE Quote  Post ReplyReply Direct Link To This Post Topic: 500 series loader cylinder repair.
    Posted: 22 Sep 2024 at 6:04pm
I have a 500 series loader with leaking cylinders. In the past, I have only had to replace the inner and outer o-rings on the piston. The packing was good.
Does anyone know the size of the inner and outer o-rings? I really don't need the whole kit.
Pete Hinrichsen
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 7:24pm
I tried fixing my 500 loader cylinders myself. I failed because my rods were slightly bent. The seals leaked when the rod was in the middle but didn't leak fully extended. I bought two agco seal kits and then bought two new cylinders. I don't know the answer to your question but I hope you don't have bent rods like me. I think agco has all.of the part numbers you need to figure out what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 8:45pm
Alex at A&W Tractor has seal kits for the 500 loader.  I got 4 kits from him for my 185 this spring.   Andy
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 6:05am
Pete
Did you remember to install the 'back-up washer' 343390 with the smaller inner 'O' ring ?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote N6PETE Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2024 at 6:18pm
Thanks for the reminder. I am sure the diagram shows what side of the o-ring the back up washer goes.
Pete
