500 loader replacement cylinders
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Topic: 500 loader replacement cylinders
    Posted: 07 Nov 2023 at 8:26am
Has anybody ever bought off the shelf replacement cylinders for a 500 loader?Is there something that will pin in without modifying the frame?  I am looking at a 500 loader but the lift cylinders are gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 5:42pm
get the diameter and length you need and take your pick...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 5:47pm
https://www.allischalmers.com/forum/500-loader-lift-and-tilt-seal-replacement_topic193219_page2.html
one of the posts on above link... see sizes below...
https://www.magisterhyd.com/product/2inch-bore-x-36inch-stroke-cross-tube-hydraulic-cylinder/
Edited by steve(ill) - 07 Nov 2023 at 5:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2023 at 5:55pm
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2023 at 12:38am
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2023 at 3:01pm
I want to also report that I did replace the tilt cylinders and used these Magister cylinders.  I used the 2 inch by 24 inch cylinder for the tilts and 2 inch x 36 inch on the lift cylinders.   On the rod end of the tilts, I actually had to shave off about 1/8 inch on both sides to get the cylinder to fit into the slot.  I used a reciprocating saw and it cut easy.
Very happy with the results so far.  Have moved quite a few things with my 500 loader since installing and no issues.  The price was around $221 and I had to do a back order of a few weeks.  With fittings, I sunk about $900 into replacing all four cylinders.  It would have cost 2 or 3 times that if I were to fix my original cylinders.
I am holding onto the original 500 loader cylinders for now in case I want to make my 190 completely original someday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2023 at 9:03am
Thank you Gents.
