500 loader replacement cylinders |
Post Reply |
structures
Silver Level Joined: 28 Feb 2011 Location: Beggs, OK Points: 333 |
Posted: 07 Nov 2023 at 8:26am |
Has anybody ever bought off the shelf replacement cylinders for a 500 loader?Is there something that will pin in without modifying the frame? I am looking at a 500 loader but the lift cylinders are gone.
Robert
1964 D15 Series II |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80171 |
get the diameter and length you need and take your pick...
https://www.allischalmers.com/forum/500-loader-lift-and-tilt-seal-replacement_topic193219_page2.html
one of the posts on above link... see sizes below... https://www.magisterhyd.com/product/2inch-bore-x-36inch-stroke-cross-tube-hydraulic-cylinder/ Edited by steve(ill) - 07 Nov 2023 at 5:54pm |
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1422 |
calico190xt68
Orange Level Joined: 12 Jan 2017 Location: Frankton, IN Points: 794 |
I want to also report that I did replace the tilt cylinders and used these Magister cylinders. I used the 2 inch by 24 inch cylinder for the tilts and 2 inch x 36 inch on the lift cylinders. On the rod end of the tilts, I actually had to shave off about 1/8 inch on both sides to get the cylinder to fit into the slot. I used a reciprocating saw and it cut easy. Very happy with the results so far. Have moved quite a few things with my 500 loader since installing and no issues. The price was around $221 and I had to do a back order of a few weeks. With fittings, I sunk about $900 into replacing all four cylinders. It would have cost 2 or 3 times that if I were to fix my original cylinders. I am holding onto the original 500 loader cylinders for now in case I want to make my 190 completely original someday.
80 7010, 80 7020. 67 190XTD Series I w/500 Loader, AC 2000 Plow, AC 4 row Planter, AC 77G Rake, Member Indiana A-C Partners, Member TAC
structures
Thank you Gents.
Robert
Post Reply | |
