500 forklift won’t go into gear? |
Compton1496
Joined: 01 Apr 2026 Location: Ashland Ohio Points: 5 |
Topic: 500 forklift won’t go into gear?Posted: 01 Apr 2026 at 11:32am |
I’m going tomorrow to pick up a 500 forklift, unaware of year or anything. Getting a pretty good deal on it, the seller says he shut off one day and the next it wouldn’t go in to gear? He says he thinks linkage may have came apart internally. I’ve never looked at this in person yet (4.5 hours from me). Is there a common issue that might cause this? I’m unsure if he means the transmission wont go into gear or the shuttle. He has it listed has a hydrostatic transmission, I don’t think that’s the case? As far as all the research I’ve done thus far so maybe he isn’t too sure about the machine. Just trying to get an idea of what I might be getting into. Thanks!
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3660 |
Posted: 01 Apr 2026 at 5:05pm |
Shhh... it is a D15 shuttle shift. More than likely the shifting fork has slipped between the shifting lugs. Pull the snap ring - remove the shifter and use a long slim screw driver to get into neutral and reinstall shifter and be careful to push the laver left or right hard before moving fore and aft. It has no reverse. The other issue is the shuttle clutch may have eaten the ridge on the shifter off and the shift collar on the power director clutch is not moving thus it is in neutral - it will have to be split. We used to cut the frame in a down back and down cut and reweld when completed - saves quite a few hours to the customer who would allow this. After cutting and supporting the frame simply unbolt the unit at the clutch and perform repairs and reweld side frames. The dealer here in the 60's sold over 50 500/600's to loggers, lumber yards and brick layers. We had a diesel unit that had over 20,000 hours -and yes it was worn out in every way and had everything replaced many times. The RH steering arm gave the most trouble. Craig Sawmill was the record owner.
Compton1496
Posted: 01 Apr 2026 at 6:19pm |
Thanks for the reply, it will give me a start to look into it. I appreciate it and will update once I have it back home and start digging in!
Compton1496
Posted: 14 hours 10 minutes ago at 7:30pm |
Okay after getting it home and checking it out better I think the shuttle is working…. It’s making a grinding noise up front. Possibly something with the differential? Engine is loading when shuttle is moved both directions
Edited by Compton1496 - 14 hours 6 minutes ago at 7:34pm |
acjwb
Posted: 12 hours 18 minutes ago at 9:22pm |
Is that the one in WV? Let us know what the problem is. Thanks
Compton1496
Posted: 12 hours 17 minutes ago at 9:23pm |
Yes it is, I’m thinking it’s something with the differential which looks like a absolute pain to get to
