50/50 Fuel Pump Leak
ScooterBuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScooterBuck Quote  Post ReplyReply Direct Link To This Post Topic: 50/50 Fuel Pump Leak
    Posted: 16 Nov 2010 at 11:05am
Can anyone give me some advice on repairing a fuel leak at the throttle shaft on the pump of a 50/50. I'd like to do it myself if possible. It has been leaking for a while but not bad. Now it is starting to leak a little more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScooterBuck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 1:14pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 2:31pm
looks like the usual throttle shaft leak on a CAV pump. Not a repair for the average do-it-your-self-er. Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 2:34pm
What little I remember from school is the CAV pump is not very friendly to work on. Sounds like a job for a pro to me...
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2010 at 4:29pm
not only that, but they get grooves worn in the top cover bore. We have covers sent off and steel inserts put in them. Where are you located? Ed.
