460 loader control valve options
farmtechguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtechguy Quote  Post ReplyReply Direct Link To This Post Topic: 460 loader control valve options
    Posted: 24 Dec 2025 at 10:36am
Greetings,
I acquired a 160 diesel with (I believe) an OEM 460 loader the other day. After using the loader a bit it's apparent I have an internal hydraulic leak as the bucket slowly sinks with a load in it.
I'm inclined to think it's in the control valve. When I go to lift the bucket, if I only open the valve ever so slightly, the loader drops. Once I open the valve enough, it lifts just fine.
My question is: couldn't I just replace the valve with a cheaper universal spool valve from ebay? I'm sure the cylinders could use a seal job as well.
Your input is much appreciated!
Edited by farmtechguy - 24 Dec 2025 at 10:38am
ac160 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2025 at 11:29am
Try changing the packing in the cylinders first.  I have a 460 loader on a 6070 that leaked down with or without a load, and new packing solved that issue.   There were two versions of the 460 loader, one for a 160 and the other for the 6060 - 6080.
Ray54 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2025 at 1:08pm
I would agree start with the cylinders first. But there is a no tools required way to check. When you first start the tractor run the loader up and let it leak down a number of times. As it is lowering put your hand on it, the bypassing oil will create heat. If you cannot feel any warming of the cylinder, then the valve is your leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtechguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2025 at 1:53pm
Thanks for the replies. I picked up a 4x5 round bale and definitely have gland seal leaks on two of the cylinders. I'll do the test you describe here in a little bit and report back.
Do you guys think an internal cylinder leak could be the cause of the "dead" spot when opening the control valves? It's pretty bad when I it loaded up.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2025 at 9:00am
I'm having a similar problem with a tractor and loader I recently bought.Except the loader doesn't leak down when sitting but when in use when a I pull the lever to raise the loader it'll drop some before it starts to go up.I'm thinking its the valve but maybe not.Taking it to a shop near Harrisonburg VA they are very good on hydraulics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:06am
Some hydraulic valves have a "load check" valve built into them. This is supposed to eliminate drop first and then lift situation.  Some of these load checks are only on one side of the spool, meaning if your lever operates backwards to lift, the load check isn't working on the load side, but the lowering side. Again, not all hydraulic valves are equipped with load checks. Your results may vary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 25 minutes ago at 9:10pm
Did you by chance buy the 160 in Orange Va? I missed out on that one. As they say a day late and a dollar short.
