460 loader/185 allis
Davej View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Davej Quote  Post ReplyReply Direct Link To This Post Topic: 460 loader/185 allis
    Posted: 15 Apr 2012 at 1:03pm
Bought a really nice 185 last spring, very pleased with it so far. Tractor had a loader on it, but was not on it when we bought it. Found a 460 allis loader that was removed from a 6080 and guy that sold it to us, assured with alittle modification, it would fit. Know we will have to make brackets for the axles, using U-bolts. Concerned about the spacing. We measured a 6080, looks like we need to add 1/2" spacer on each side. Any suggestions on mounting this loader. Tractor has a cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 1:06pm
Make sure you have heavy tubing or heavy angle iron go under the rear axle so you don't break the tractor in half.....been there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 5:36pm
I,m gonna do the same to a 180 , it can be done , have to drill a couple new holes in the frame too - and make sure to brace it like the Dr said or it will break the PD houising
Post Options Post Options   Thanks (0) Thanks(0)   Quote Davej Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 12:23pm
Thanks for all of the info. I will have to drill that new hole in the frame. Will you be leaving the wrap around weight on the front. Also, do we need to put 1/2" spacers on each side of the frame to spread the loader out. The 6080 that I measured was 1" wider then our 185. Nothing like a good project.
This page was generated in 0.023 seconds.
