45 Nelson muffler question
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 45 Nelson muffler question
    Posted: 12 Mar 2010 at 8:58pm
Just replace manifold gaskets on my 45 and it has a Nelson on it.  This is the first one I've had personally and have a question about it. Is there some sort of a gasket that would go into bottom of it or anything like that.  When I set it down on and it "bottoms" out, the holes are about 1/2 a hole low so I have to Raise it to get bolts in.  I notice that it still puffs exhaust downward around the bottom of the muffler.  If I take bolts out and let bottom out, it does not blow exhaust out.  Thanks, LArry
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 8:35am
Larry, I have not seen that before on a Nelson muffler. I don't know of a gasket for one.
You might just slot the bolt holes out on the muffler a little to get it down in the manifold.
Don
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 10:24am
Larry, Do you think someone put a CA muffler on it??
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 2:23pm
I'll look for a number on it and see.  I think the guy i bought the tractor from put it on and got it from the AGCO dealer in Ashland.  Slotting the holes would work ok also I guess
This page was generated in 0.088 seconds.
