433I valve cover bolts
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 433I valve cover bolts
    Posted: 04 Sep 2022 at 8:36pm
I am changing the valve cover gasket on my 6080 and noticed the previous owner had oversized nuts as spacers over the shoulders of the bolts.  The parts book appears to show a stack of flat washers as spacers.  What is the reason for this and is there anything special about them.  Can I use ordinary flat washers instead?
Many thanks!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2022 at 8:48pm
They have to have the correct number of spring washers or it will tighten down too tight or too loose. If I remember correctly it is seven spring washers.                 MACK
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 6:44am
It should be a shouder
bolt so it wont tighten too tight. Ive never seen one leak with that shoulder bolt and spring washer kit
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:01pm
They are NOT flat washers.They are kinda "w" shaped. I was thinking they face each other every other one. It's what's on 8000 series 426's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2022 at 9:46pm
They were shaped like a disc blade. Every other one was stacked and it was like a spring.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 8:13am
They sound like 'bellevill' (sp) washers, which are a form of spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 9:47am
Bellville washers. Seven of them taped together to make them as one. Trouble is with time and heat the tape deteriorates and then you have seven individual parts laying in a pile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 12:58pm
Sooo....positioning is...with bolt in position, bottom one facing down against cover then next pair facing each other then repeat again for the 2 pair left? Only trying logic. How'd I do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 2:39pm
BINGO  !!!   We have a winner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 3:55pm
wonder why they didnt use a thick rubber washer ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 7:27pm
Many thanks!  Going to try ordering them from AGCO tomorrow.  Hoping they are still available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 9:04pm
I'd say because the washer setup would last longer....My 220 just has Phillips head screws through the gasket. Old school it is but has never been a problem in over 30 yrs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 9:10pm
Pt #74036977 still listed with a price so must be available? $55.87....wonder if that's per fastener? Doesn't say. Call a dealer.They can find out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 9:58pm
Might be a whole "kit" for one engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 11:34pm
Just the washer stack #74036973
