426ci main bearings ??? D21
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: 426ci main bearings ??? D21
    Posted: 06 May 2024 at 10:46am
From what I gather this is the only way that these new main bearings are avaliable.
These are .010"
Old ones are wider then the new ones by 0.197"
Does anyone have some insight on this?
Thanks, Dan
Edited by Acdiesel - 07 May 2024 at 10:43am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 2:58pm
At some point they made the journal radius larger on the crank and wide brgs wont fit. If you have piston cooling from mains all the uppers are for that application. If cooling through rods you will lose some psi unless you strip crank out and drive the little steel balls in main saddle. I doubt that's what you have since it's got the wide brgs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 10:54am
Non- piston cooled
Engine # 3D-05778
I should not have any worries using the updated bearing assemblies and following the service manual on the reassembly of the the components?
Thanks, Dan
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 11:18am
New bearings will work fine. Get new conn rod bolts. Be very clean assembling the rod caps with those serrations in them. Any dirt is bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 8:32pm
I'd have to look. I think book wants slot on cam side. Yours doesn't need the slot but that's all they make.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 10:57am
thank you, I dont like it when manufactures change designs.
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
This page was generated in 0.039 seconds.
