426 vs 301 flywheel
brad durst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Topic: 426 vs 301 flywheel
    Posted: 23 Apr 2020 at 10:09pm
is the crank shaft bolt patter the same one a 301 and a 426? IM not worried about the bellhosing will a 301 fly wheel bolt right on to a 426 thanks
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 8:51am
Not even close. If you are going to use a 426 in a 301 chassis, you will need a custom built flywheel. Not sure what level of competition you want to run at, but if it is LLSS class I would skip the foreplay and go directly to a 4 X 11 inch clutch. 3 disks won't be enough if it runs hard.
This page was generated in 0.234 seconds.
