426 rod bolts |
Post Reply |
Kevin210
Silver Level Joined: 08 Oct 2018 Location: Indiana Points: 377 |
Posted: 23 Jul 2021 at 8:38pm |
What do you guys think about getting new rod bolts for a rebuild on a 3700 engine or using the same ones.
Orange Level Access Joined: 12 Sep 2009 Points: 20485 |
I've always replaced rod bolts on 2000 and 3000 series engines. Many don't and get along fine. I know of many newer generation engines that want rod bolts and head bolts replaced when the engine is apart. Tell me how new rod bolts could be a bad thing ??
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4910 |
Doc makes a good point, many think those bolts stretch over time after being torqued. A good idea in my opinion if they are available.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8239 |
The instructions with 426 rod bolts say when torqued to final of 85lb they are stretched and not to be reused. Just got done with that job and a pair was $32 more or less.
Kcgrain
Orange Level Joined: 24 Sep 2009 Location: Wisconsin Points: 769 |
I can tell you one way that new bolts are a bad thing. Allis Chalmers had standards in bolts that they had the ability to test and make sure they lived up to the standard. Agco for example just puts a bid out for 1000 bolts grade such and such, and the lowest bidder gets the job, and the bolts may or may not be up to the standards Allis Chalmers required. I know of 2 engines that failed after Agco rod bolts broke. To be fair that was a while ago, and I heard, but dont know for a fact that Agco was buying ARP bolts now, but cant confirm that.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8106 |
Id go for quality in this matter- thats something you dont want to break
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4911 |
AGCO supplied Rod bolts for a 426 ARE indeed ARP, and they include a special bulletin just for them. I've had to reuse the ones in my puller several times. As long as a Rod bolt stretch is monitored, it can be reused, but it's junk if ever over torqued from a cheap out of calibration tq wrench. (or not so cheap, my TQFR Snap On Tq Wrenches will read high when tested.
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4525 |
Found that AGCO uses ARP rod bolts when I rebuilt my D21 engine in 2004
SteveM C/IL
ARP is stamped in the head...
Genedujyn
Bronze Level Joined: 25 Aug 2023 Location: Seattle Points: 1 |
Ah, the classic rod bolt debate – it's like choosing between your favorite old-school game or trying out the latest title. Reusing the same ones can feel like sticking with a character you know inside out while getting new ones is like embarking on a fresh adventure.Speaking of adventures, if you're searching for top-notch bolts and screws, I've got a nugget for you – https://www.scrooz.cоm.au/. It's like a digital treasure trove for all your hardware needs.As for your engine rebuild, it's like leveling up your skills in a game – each choice counts. Whether you're leaning towards nostalgia or embracing new beginnings, may your rebuild be as rewarding as a well-crafted storyline.
Edited by Genedujyn - 28 Aug 2023 at 10:21am |
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3294 |
Many decades ago one of the service reps who raced and was familiar with ARP got tired of hearing bad things about AC rod bolts and convinced them to source the 426 rod bolts from ARP - as good as one can get - never had an issue.
Post Reply | |
