426 oil cooler oil leak
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 426 oil cooler oil leak
    Posted: 26 Dec 2024 at 12:03pm
I have a 426 that was in a 7045 that has a slow oil leak between the bottom of the housing and the rear elbow, can l remove the six bolts and slide the elbow back and out to replace the gasket with out disturbing the cooler o-rings or I'm asking for trouble ? Thanks Dave
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 3:59pm
Is this a leak at the block - water - at the bottom of the elbow or the bottom of the cooler on the rear elbow. IF you pull off the rear elbow you have to replace 2 gaskets anyway - might as well take a day and do the whole thing unless it has been done lately,  and check the relief valve.  We have more trouble with the elbow to block gasket that anything. We use the old tech trick of gluing a circle of 6 # test fishing nylon line to the gasket on both sides of gasket with Indian head stuff the day before installing to the block.  It is very frustrating to do the job then see a trickle of antifreeze the next day...like I have...  74028823 is the block gasket at rear and cooler gasket is 74028822 and there are 2 separate holes at the bottom - not joined as the early ones -70933325 are the lube contact orings-70923637 are the water side and 74028820 and 70923621 are the tube orings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 4:00pm
can get the other pn's if you need them
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 4:08pm
Originally posted by tbran tbran wrote:
.... We use the old tech trick of gluing a circle of 6 # test fishing nylon line to the gasket on both sides of gasket with Indian head stuff the day before installing to the block.  It is very frustrating to do the job then see a trickle of antifreeze the next day...like I have..
This is the kind of knowledge that's in danger of being lost if not passed down. Smile (I'm 43 & never heard of it before)
I'm guessing the fishing line is a "double whammy" in that it squishes out and creates an extra sealing layer as well as giving you more squeeze on the gasket paper?  One to commit to the memory banks anyhow, be plenty fishing line left years after the last of the RTV has gone bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 4:29pm
Yes tbran its the #74028822 gasket that is leaking engine oil at the bottom between the cooler housing and the elbow, Thanks Dave
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 4:30pm
we do that on the left rear and back of the head gaskets on 426's but don't glue them - almost every engine seeps there... saw that 'trick' in a 1972 AC service school... also there is a correct position of the brass cooler in the housing as well - just like the cooler cores in intercoolers...
Edited by tbran - 26 Dec 2024 at 4:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 9:29pm
How do you keep fishing line in place on a head gasket without gluing it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 7:57am
You just lay it on the block, lay on the head gasket, put the string around the back corner and side top of the gasket and put on the head. The string has a natural curve. It only takes about a foot. This just mimics some gaskets that have a slight ridge of material in certain areas prone to seepage.  IF the string doesn't want to lay right a slight coating of sticky Indian head on the thin nylon string is so small it will not be a factor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 7:58am
Since it is oil leaking - do the whole thing...
