426 inj pump
ralph cooley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ralph cooley Quote  Post ReplyReply Direct Link To This Post Topic: 426 inj pump
    Posted: 31 Jan 2014 at 3:58pm
need an adapter to put on a bosch A pump on a 426
email dimock3@gmail.com
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2014 at 1:51pm
No adapter needed. You just turn the pump front bearing plate which is the pilot, down from 3.35" to 3.25"(has to be removed)then just drill new holes on front plate, and plug the old pump mounting holes with short bolts, or welds? I do however have the adapter hubs in stock to put on the A pump, and then use a DM pump gear. The hubs are $100, but need the timing mark put on them by your pump shop, or I can do it if I have the pump. Good luck! Ed.
This page was generated in 0.088 seconds.
