426 head removal |
Kevin210
Topic: 426 head removalPosted: 29 Aug 2019 at 5:57pm |
OK guys I need my memory freshened up some on
removing the head on a 3700 motor. I replaced a couple of sleeves and pistons back in the 90's but that's been a while. What sequence do you use to remove the head bolts for example. Will a 3500 head and a 3700 head both fit on the same block. And what about swapping the front covers also,will the 3500 water pump circulate enough coolant to keep the 3700 cool or would I need to use the 3700 water pump. Thanks guys. |
DougS
Posted: 29 Aug 2019 at 7:00pm |
Usually you loosen/remove the bolts is the opposite way you install them.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 30 Aug 2019 at 11:06am |
i put a 7040 head on my 220 30yrs ago. Direct fit
