426 gas
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Topic: 426 gas
    Posted: 12 Apr 2015 at 7:44pm
Has anybody ever converted a 426 over to gas? Just wondering because a local guy is running a 466 deere on gas in his 4010 and I thought it would be a good idea for the D19 since the engine in it is junk.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 5:07am
They run em on alchohol, so why not gas.  Sounds interesting
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 10:36am
E85 is even better; Around here it's pump gas not racing fuel. Many classes ban racing fuel.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 5:00pm
Put the spark plug in place of the injector then use crank triger ignition system cut the top of the piston to lower static compression and ratio only thing I havent com up with is intake manifold and a flywheel the size of the 301 drop it in a 190 and eat up some red
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 10:46pm
I'm pretty sure that is how the 4010 is. Running in the naturally aspirated class that we do the 466 gas 4010 usually does better than the 466 diesel 4010. Plus with our rules I don't think i could run a d19 since it came factory turboed. They might not care at first unless it started winning, then your'e out. Lol
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 6:28am
Remove the diesel decal from the D19 and it's then a gas tractor and non-factory turboWink
In those non-turbo type classes around here the spark ignition tractors rule over the diesels.  1/2 HP per cubic inch is easy with most spark ignition engines, 200 HP in a 19 sounds like pure fun.  For more serious fun 1HP per cubic inch is obtainable with $$$
If you get serious I have an idea for the flywheel. The military generator engines have seriously large and heavy one piece flywheel that is useless for the normal tractor applications and they get tossed in the scrap bin. There is a lot of meat to work with but you would need a buddy with a VTL or large swing engine lathe.
Edited by Butch(OH) - 16 Apr 2015 at 6:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 8:15am
Well i'll keep this idea on the table, but working on a 451ci farmall M right now, so it'll have to be in a little while. The farmall is nice, but i'd still rather be on something orange. Haha
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2015 at 1:09pm
I have a fresh 426 head that is ready with plugs in it, I have the header flanges to go with it as well. I also have a complete electromotive crank trigger ignition system. And various other parts. Pm me if interested.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2015 at 9:48pm
I'm running a 426 decubed to 360 on gas. MACK
