426 exhaust manifold
AC 7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 426 exhaust manifold
    Posted: 08 Oct 2014 at 8:54pm
Has anyone used the exhaust manifold from crank machine for a 426 on a hotfarm tractor. Dr. Said use one off a in 414 which would be better. Thanks for the help.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2014 at 9:26pm
What's "crank machine"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2014 at 9:56pm
Crank machine service from New Baden IL they offer a new cast center feed exhaust manifold I think it is suppose to be similar to the D 21 na manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2014 at 10:43pm
as long as it is divided all the way to the turbo it will be better than any AC manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2014 at 8:10am
Will the divided manifold help if the exhaust housing doesn't have a divider in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2014 at 8:34am
Yes. It would work better with a divided exhaust housing, but the exhaust pulses are better used with a divided manifold from what I understand.
Edited by O.P.S. Heads - 09 Oct 2014 at 8:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2014 at 12:07pm
The IH manifold has three advantages over the A-C manifold. #1. The exhaust flow only turns once coming out of the head (left or right) #2. the runners are a little smaller than the A-C keeping expansion from occurring until it hits the turbo #3. absolute pulse flow with built-in divider wall. The best IH manifold would be from a truck which would position the turbo down on the side instead of up under the hood. I haven't seen this after-market manifold, but doubt that is has more than the divider wall and flunks on #1 and #2.
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2014 at 7:47am
The IH manifolds don't have  same bolt hole spacing and are not a true center dump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2014 at 5:33pm
You have to make 1 inch thick spacers to adapt to the A-C head. Been there....dun that... it works better than ANY A-C exhaust manifold. The best would be the IH truck manifold.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2014 at 7:11pm
The one Crank Machine Service is making is a much bigger, and better looking setup for pulling. It's just whether your rules would allow since it's not oem, and couldn't pass for oem either. The cms that posted is the builder. Dan Karpel, 618-401-2386 is on a card I have.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2014 at 7:17pm
Will the IH manifold clear the stock oil cooler pipe on the 426?
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2014 at 7:35pm
I did it to a D-21 and had the oil cooler removed for the in-line injection pump, so I can't really answer your question with certainty.
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2014 at 9:36am
The manifold I have does fit with oil cooler on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2014 at 9:38am
Some pictures would be awesome!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2014 at 10:36am
Seen some pics of the CMS manifold and I dont see a divider in the manifold. Im not saying that its bad but it really wouldnt be any better then the stock D21,210,220 manifold. Otherwise it looks nice.
One company I'd love to have build a manifold would be "Steed Speed" look up the manifold that they build for the 5.9Cummins
Edited by peterson - 12 Nov 2014 at 11:04am
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2014 at 11:31am
The pictures are the first one out. Have dividers in all manifolds have some with out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2014 at 11:32am
How much for one with divider?
This page was generated in 0.085 seconds.
