426 crankshaft gear
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 426 crankshaft gear
    Posted: 23 Feb 2016 at 7:07pm
Working on a 220 with a busted camshaft. Camshaft gear and all other gears look great except the crank gear. Should I replace this gear or do you think she will run? No metal shavings or pieces were found in the oil or the pan. Thanks!
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 7:45pm
Probably never bother but I think I'd go to the trouble since it's right there in the wide open.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 9:35pm
Will knock like a bad rod bearing.     MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 7:40am
Yep MACK is right. BTDT
Wink
I am a Russian Bot
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 7:45am
Yuck! Looks like a chunk is off the gear in the upper left too.
Edited by Jordan(OH) - 24 Feb 2016 at 7:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 9:18am
No, thats just the way the picture looks.  Those gears have a taper cut to them.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 11:27am
Joe if you need a gear let me know probably have a few off in the shelves Niel
This page was generated in 0.083 seconds.
