426 block heater
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Topic: 426 block heater
    Posted: 06 Feb 2019 at 7:05pm
I am wanting to put a block heater on a 210. Does anyone make a screw in for the plug in the block? I haven't tried AGCO. If I use tank style heater where would I plumb the in and out lines? This tractor has a coolant filter and original engine.
Edited by BKarpel - 06 Feb 2019 at 7:06pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 8:15pm
AGCO parts books show one # 70256703. Phillips Zerostart # 3500013 may fit.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 9:51pm
Factory heater goes in the rear of the oil cooler. I would thing a factory unit would cost less then the plumbing for a tank heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 3:28pm
[QUOTE=wekracer] Factory heater goes in the rear of the oil cooler. I would thing a factory unit would cost less then the plumbing for a tank heater. [/QUOTE
Are you talking the cooler on a 210 or 7-8000 series.Agree on later units but no so sure on the old 3500's.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 5:22pm
They go in the same spot.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 7:20pm
This is what I installed on my 220. It is 1" pipe thread hole to rear of oil filters.
Edited by JimWenigOH - 07 Feb 2019 at 7:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 10:31pm
Thanks for the picture Jim. That is where I thought one would go. Will try getting the plug out or install a tank style if it doesn't budge. Earlier 426 blocks dont have a big tube style oil cooler.
Edited by BKarpel - 07 Feb 2019 at 10:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 9:02pm
The heater is a Kat's 11407, 1" NPT, 400W. Works good. I didn't want the long cord that came with the heater hanging on the tractor so I bought a 12" cord, Kat's 28206. The heater can be bought on eBay for under $40.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 9:45pm
This is the 600W heater I removed when I installed the plug heater, just another option.
Edited by JimWenigOH - 10 Feb 2019 at 2:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 9:48pm
On the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 6:11am
I wouldn’t think that would work very well. If the thermostat is closed It would have a hard time circulating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 6:53am
Years ago, I saw lots of those lower hose type heaters on AC tractors. Were they as powerful as a 1500 watt tank type heater ?? Nope. But they were easy to install and certainly were better than a dipstick heater or an oil pan magnet type heater. Try and install a tank heater on a D17 or WD45 gas engine. A lower hose heater is a piece of cake.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 7:15am
If I could at all make a block heater work I’d take it over a tank heater any day.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2019 at 1:58pm
The bypass hose will allow enough to circulate.
PDehring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 6:58pm
I see in Kats' catalog, they list a 1500W for the 3500/220.  How long does it normally take to warm the block with the 400W?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2019 at 7:56pm
I usually plug it in at least an hour or so prior to starting the tractor. Tractor is always in a barn when not in use.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 9:02am
I used the 1500 watt on both our 8050's will start at 20 bellow pretty easy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 4:54pm
The Kats 1500 watt P/N 30207 that is listed on their application chart was too long to fit into my 220, that's why I went with their 400 watt P/N 11407. Double check me by removing your 1" plug and measure your maximum insertion depth.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 6:43pm
70256703 no longer serviced by AGCO
Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 11:47am
Ok, perfect, that's what I needed to know.  I'll check when I pull the plug but I'll stick with the 400W just to be on the safe side.  I still need to get another heater for a 3400 engine.
Thank you sir.
Edited by PDehring - 27 Nov 2019 at 11:48am
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 3:35pm
Kats 30207 is 3 1/4 long For The  older 426 Engine Like The 210 and 220 Kats 30303 is 5 long For The Later 426 Engine Like 3500 and 670 From  7030 to 8070 You Can Use 30207 In All The 426 Engines It Is A 1500 Watt Heater
Edited by Alvin M - 27 Nov 2019 at 3:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2019 at 7:26pm
I installed a Kats heater in a 220 earlier today.  Before I did, I measured the depth of the cavity with the plug removed and it is only 2" (from the outside of the block to the back of the cavity).  There is a deeper part of the cavity but it is not centered with the hole so a longer heating element will not work.
11407 is the correct part number for a 220/3500 even though Kats catalog lists the 30303.
1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2019 at 6:50am
Is there one of these heaters available for the 301 block?
