426/670T engine torque
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Topic: 426/670T engine torque
    Posted: 23 Sep 2022 at 9:52am
Sort of a random thought as I was working through this on another machine; does anyone know the actual engine torque rating on the 426?
Working the horsepower formula backwards gives a 158hp engine at 2300 rpm around 360lbs of torque, but that's only the torque it produces at that particular rpm
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 10:58am
Depends which HP rating the engine is sold as. I've got the specs at home and I think a 670-HI at 220 HP/2400 RPM has a peak torque of 440 ft lbs at 1700 RPM. The 158 version would be less.  1700 RPM seems to be their "peak" RPM on all their engines, by design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 7:07pm
Update:  670-T/ 3500 engine rated at 158 flywheel HP @ 2300 RPM makes 410 ft lbs torque at 1400 RPM.   The 670-HI/ 3750 engine rated at 220 flywheel HP @ 2400 RPM peak torques at 488 ft lbs at 1700 RPM.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 7:31pm
How does that compare to an IH 414 or JD 404?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 7:36pm
Well, a Deere "404" was never known for big low end torque numbers. Now, the Deere 466 is another matter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2022 at 10:16am
Very interesting, thanks for looking it up.
Matt
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2022 at 11:21am
Does the torque rating drop at pto speed or stay the same? Just curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2022 at 4:20pm
depends on the ratio of engine speed to pto speed..
As DOC said, a given motor may make max HP at 2400 RPM, but max TORQUE at 1700.
if your motor has a max rpm of 1800... then the max torque might be at 1400 rpm.
PTO speed of 540 is RATED at a given Engine speed... normally not at HIGH IDLE.
you CALCULATE HP by measuring  TORQUE and RPM...
HP = TORQUE x RPM / 5252
most engines ( tractors ) will have a flat torque curve between 1200 - 1800 rpm with the "max" just a little higher somewhere in that range... HP will be higher as speed increases due to the formual... if TORQUE is basically constant and RPM keeps increasing, then the "calculated" HP keeps going up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2022 at 4:24pm
A "generic " curve might look something like this... The idea of a tractor is, as you PULL DOWN and load it ( 1400 - 1700) you get the MAX PULL --- TORQUE..
This page was generated in 1.824 seconds.
