416H no spark
Brian L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian L Quote  Post ReplyReply Direct Link To This Post Topic: 416H no spark
    Posted: 29 Jun 2019 at 8:39am
My Little Allis was running poorly cutting in and out.Decided to give it a complete tuneup.Went to John Deere bought Kohler points and condensor,replaced wire from coil to points as it was showing old age.Have no spark at all.Suspected bad condensor so changed it still nothing.Put in a new NGK plug and took the coil off My WD nothing.Have power to the coil and no wires grounding out.I am at a loss.How do I check the points side off the points with a Volt meter.Help please
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 8:40am
Sorry ment Points side of the coil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2019 at 6:07am
Well it ended up being a dead short in the Rectifier unpluged it and fired right up.Replaced it and good to go.Put a new carb on it while I was at it throttle shaft was wore out.Had this 416 for 30 years still does not use any oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2019 at 8:31pm
Glad you got it fixed. They just don't make em like they used to. No box store mower will last half that long.
This page was generated in 0.506 seconds.
