410 Leaking gas tank
A-Cvtx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Topic: 410 Leaking gas tank
    Posted: 14 Jan 2015 at 5:06pm
Finally got my new 410 running. Now I have a leaking gas tank. It's plastic....... Ideas for fixing? Leads on a replacement? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 9:05pm
Depending on where and how big the leak is, sometimes a little batch of epoxy will do the trick in makin' the fix. You may be able to find a good used one on e-bay or be able to purchase a new one. Try Brenda at Sandy Lake Implement. They may be able to get you a new one yet. Some of these same tanks fit a lot of different model Tractors... HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 4:15am
Thanks Steve! I'll give them a shot. Would like a new one if possible.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 8:52pm
The tanks are a common problem on the 400's. Unfortunately the tanks are unique to the 400 Series and haven't been made since probably the early 80s. When I bought my 416 the tank was missing. A couple years ago I bought another 416 for parts. I leak checked the tank and everything seemed OK. A couple months later it began to leak at the seam. I would try to fix the existing tank if possible, even if just for a backup.
This page was generated in 0.169 seconds.
