400 series loaders |
Cradke
Topic: 400 series loadersPosted: 16 Nov 2016 at 6:31am |
I just got the manual and I see what you mean about the rear brackets. Thanks for the information. I installed a front mount pump on the d17 as well. I had to cut the pump shaft down 1-3/4" for it to fit. I'm assuming because the d17s engine is bigger
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10874 |
Posted: 14 Nov 2016 at 8:03pm |
The D17 brackets are made from a heavy angle iron. They have a bend in them. If you don't have a manual. PM me your cell and I will text a drawing from the manual so you can see what they look like. HTH Tracy
TimNearFortWorth
Posted: 14 Nov 2016 at 7:06pm |
Cut the brackets just under the foot rests, attach the rear hardware to the axle and graft in angle iron to make up the difference.
Cradke
Posted: 14 Nov 2016 at 3:48pm |
I would like to post some pictures on here but I don't know how to do it.
Cradke
Posted: 14 Nov 2016 at 3:45pm |
Looks like I'm going to have to do some checking around for that bracket. Otherwise i will make one. The d17 I have has only 1 input and output for the tractor hydraulics so I purchased the front pump with the loader. The pump input shaft seems to be about 2" too long. Does anyone have any more information about the pump sizes? I also would like to know if the loader arms and loader brackets are all the same for the 400 series loaders. Thanks for all the information.
Posted: 14 Nov 2016 at 1:04pm |
If you noticed, the axle brackets are bolted on. Any D-17 takes different axle brackets compared to any D-15. You need D-17 axle brackets, or fabricate them from angle iron.
Cradke
Posted: 14 Nov 2016 at 1:01pm |
Can someone tell me the difference in the 400 series loaders. I bought a loader off of a d15 series 3. I went to mount it to my D17 series IV and it doesn't fit where it ties into the rear axle. It is about 10" too short. Would I need to buy just the rear mount for a 400 series loader to fit my D17?
