4 Wheel Drive Conversion
MiPlowboy1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MiPlowboy1 Quote  Post ReplyReply Direct Link To This Post Topic: 4 Wheel Drive Conversion
    Posted: 14 Feb 2017 at 6:34pm
Has anyone tried or thought about trying to convert a WD or WD45 to 4 Wheel drive?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 7:21pm
Yeah, I've thought about it. That's as far as the idea ever got. Lol
I did see a photo of one once that had a successful conversion.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 7:35pm
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 7:58pm
I have wondered if there was a way to put a ford elenco kit onto my d15 but couldn't figure out where I would hook in the drive shaft for the front end so I gave up fast.   Sure would be nice on a loader though.   I came to the conclusion that hydraulic assistance would be the best option there where some kits out there but I forget what ac tractors they fit. I never understood just how they matched the rearend speed. In the end i decided 2 wd was good enough for me. If I ever saw one of the elenco kits for a farmall M or h I would jump on it but I expect those bring way more money then I could afford. Basically those kits are the front axle from a dodge power wagon cut down and with modified steering linkage. As I said the tricky part is where to hook up the drive shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 8:01pm
A buddy of mine has a ford 801 diesel with 4 speed standard a reverser and elenco 4wd. That is a nice tractor even if it is a ford. Great loader tractor but no live power.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 8:07pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 8:10pm
I've seen a couple at shows over many years. Both lost the hand clutch and the hydraulic system. They had cut down front axles that looked like old power wagon ones. One had what looked to be a WC transmition with what looked like an old jeep transfer case between that and the WD transmition. The other had what looked to be a truck transmition with half a NP 203 transfer case between the clutch and the WD tranny. I saw one drive in the parade at rollag but it had the front drive shaft removed at the time.i don't have any pictures and it was a very long time ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 8:21pm
http://nh.craigslist.org/grd/5960924727.html
You could sell the wd and buy that probably you will have less invested when all is said and done and more hp....
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 10:21pm
I always wanted to make one articulated and run a chain down from the pto to a driveshaft that went to the back unit. Then make a cable operated shifter going to both transmissions. You could use the pto for a front wheel assist too if you pick the right gearing and only engage it in that gear, but the hand clutch wouldn't stop it from moving. On a WC you could make a drop box between the transmission and rear end.
Edited by 7060 - 14 Feb 2017 at 10:24pm
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 12:09am
I know where there are 1-2 of them county ferd tractors sitting
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 12:23am
I need one of those County Ford's....those are too cool!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 2:15am
I wonder if they have live power. The pasquali doesn't.   I sort of wonder if ford had someone like pasquali built it for them. All I know about them is that one has been for sale for about 2 years.
Edited by Dan73 - 15 Feb 2017 at 2:16am
This page was generated in 0.313 seconds.
