3pt questions
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Topic: 3pt questions
    Posted: 26 May 2010 at 7:23pm
I am working on building a cat1 3pt for my WD from some scrap I got lying around. I am still in the design stage and I can's settle on a few questions. I only plan on using the 3pt for a back blade and possibly a single bottom plow. I also want everything to be removable in an attempt to keep it original. So here are my questions.
1. How far past the tires should I extend my arms. Is there a standard or is it measured by the distance to the PTO shaft?
2. I was considering using chain instead of a side link. Other than being cheap looking, is there any downside to this that I should know of. I plan on using 3/8 inch chain with a 6600lbs working strength.
3. Will the draw bar hanger on the WD support the lift arms? I am planing on bolting my arms to the 5/8 hole in the side of the hanger.
So that's what I got rolling around in my head. Any advice would be appreciated.
Thanks,
Brian
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 8:22pm
only problem with chain is that you can not control the angle of the implement from left to right. been their done that.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
This page was generated in 0.081 seconds.
