3pt position control doesn't work.... |
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Topic: 3pt position control doesn't work....Posted: 16 Mar 2012 at 9:35pm |
I have a 175 and a 190 that the position contol (height/depth) lever doesn't do anything. Is this a linkage problem or a valve problem? Is the traction booster and position control handled by that same valve?
ALLIS EXPRESS!
This year: |
MACK
Posted: 16 Mar 2012 at 10:02pm |
If the linkage is all there they need abjusted.
Yes they operate the same valve. MACK
Eldon (WA)
Posted: 16 Mar 2012 at 10:12pm |
So if the tb valve is free and working it will be in the linkage? Kinda hard to see how things work under there, but at least I have a couple of tractors that work right...guess I will park them together and start studying.....the 175 I swapped out the L shaped mounting plate because it was rusted in half...maybe the linkage got repositioned wrong when I bolted everything back together. The guy that designed that mess must have been on drugs LOL!
ALLIS EXPRESS!
This year: |
Allen Dilg
Posted: 16 Mar 2012 at 11:02pm |
Hello Eldon On my son's 175 we have had a problem similuar. From what I remember see what section in the valve body has the traction segement and remove the cap on the rear of valve, gently push- pull the spool, it needs to move. Hope this helps
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 16 Mar 2012 at 11:31pm |
Youve got something out of adjustment or just plain stuck. On a 190 there is a linkage on the right side that piviots on a boss on the front of the rear axle housing. That link can be turned upside down during a rear end split. Check it on a couple of your 190s!! Good luck!!
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 16 Mar 2012 at 11:40pm |
The position control is not in the valve body. Check the linkage - there is a piece of the position control that comes off the right side draft link. I've seen several that are broken (including mine), that would explain why it does not work.
