3-Point Hitch Conversion Kit |
Joined: 11 Sep 2009 Location: illinois Points: 90904 |
Topic: 3-Point Hitch Conversion KitPosted: 10 Jul 2021 at 3:49pm |
yes... your lift arms may have latches on the top -- another variation.
Edited by steve(ill) - 10 Jul 2021 at 3:52pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 10 Jul 2021 at 3:37pm |
You would think anyone selling these 3pt concoctions would send along a good set of instructions with pictures for their customers that have paid a bundle to get there fingers pinched and backs sprained. However I suppose that's too much to ask from the parts pimps.
The ones made like the bottom picture that are poor copies of the original Allis Chalmers are better because if you have one for every piece of 3pt equipment they can be left on the implement and then hooked up as easily as any other Snap Coupler equipment. Also you have the advantage of not needing to re-adjust all the settings when switching implements, as with Snap Coupler equipment.
Brian G. NY
Posted: 09 Jul 2021 at 9:35am |
If the top is wide enough to fit the latches (and from the picture, it doesn't look so), good but why so wide on the bottom end? That appears to be the area where the biggest problem would occur. Looking at the other picture, it looks like there is an adaptor for attaching to the latch. Edited by Brian G. NY - 09 Jul 2021 at 11:04am |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 09 Jul 2021 at 9:05am |
They are that wide and that bolt size to work with the latches
Brian G. NY
Posted: 09 Jul 2021 at 9:02am |
I wonder why they make the "mouths" on the adjusting links so wide........seems like the bolts, especially the ones connected to the lower arms would be prone to bending. If nothing else, it would seem a larger diameter bolt would be used.
1953ACWD
Joined: 01 Nov 2012 Location: Lancaster, PA Points: 78 |
Posted: 08 Jul 2021 at 10:03pm |
I guess I'll need to take the snap coupler bar off and use the draw bar instead.
1953 WD - Grandpop bought new, sold to neighbor in 1965, I bought back in 2001, restored 2021; 1974 175 Gas; 1980 5050 Diesel, w/400 Loader
Posted: 08 Jul 2021 at 9:13pm |
There are two types for 3 points... one uses the snap coupler bar, the other uses the draw bar as shown above........ this is what you have.
Edited by steve(ill) - 08 Jul 2021 at 9:21pm |
1953ACWD
Posted: 08 Jul 2021 at 9:09pm |
Thanks, Steve. My WD has a snap coiupler and the lift arm latches. The OKTractor kit appears to work with the lift arm latches with no problems. However, do I need to take the snap coupler off and use a regular draw bar?
Posted: 08 Jul 2021 at 8:58pm |
this is off their web site
1953ACWD
Posted: 08 Jul 2021 at 8:38pm |
If anyone has a good picture of an assembled OKTractor new style 3-pt. hitch conversion kit for the WD, I'd much appreciate it if you would upload it or email it to me. We're trying to figure out how to mount it on the WD and don't have an illustration, instruction or picture. Thank you.
Edited by 1953ACWD - 08 Jul 2021 at 8:44pm |
