390 HAYBINE SCRAP OR REPAIR |
1946WP ![]() Orange Level ![]() ![]() Joined: 25 Apr 2010 Location: mn Points: 780 |
![]() ![]() ![]() ![]() ![]() Posted: 04 May 2012 at 9:44pm |
I HAVE A 390 AC HAYBINE WITH BAD WOBBLE BOX. IT'S PROBABLY WORTH MORE IN SCRAP IF I CAN'T FIND A WOBBLE BOX. ANYBODY INTERESTED IN ANY OF THE OTHER PARTS, BEFORE IT GOES.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10764 |
I wish I had one. I would make from scratch a wobble box that would last. It can be done, I have done much harder. Can't find one close enough to get. Tracy Martin
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1029 |
While we are on the subject of AC haybines,I believe they made 3 models-904,829 and 390. Does anyone know what order they were produced in? - Just curious - And was there one that was better than the others or did they all have wobble box problems?
Don Jr NY ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Waterloo NY Points: 358 |
The 829 was first made from 1966 to 1968 and it had a pitman arm drive for the sickle similar to the drive on the 90 all crop harvester. The 904 came next made from 1969 to 1971 with the wobble box drive. The 390 was last made from 1972 to 1975 also with the wobble box drive. The wobble box was the weak point in both machines. The entire hay and forage line was dropped in 1975. I have one of each model and my personal opinion is if they had adapted the twin wheel drive to these machines they would have been a much bigger player in the market. Don Jr.
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1586 |
I saw one (390) at an auction that was converted over to a John Deere wobblebox off an 800 swather. It didn't look like it would be too hard to do if you have a welder to make some custom mounts. Parts availability for the JD wobbler would be much better. Edited by AllisFreak MN - 05 May 2012 at 8:42am |
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
Is the wobble box used on any other A-C machine such as the corn head on a 780 forage harvester?
JimWenigOH ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: NC Ohio Points: 1183 |
Would a SCH Pro-Drive box work on that?
Oldoug ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 1134 |
How much do you want for it instead of scrapping it?
Matt Folkers
FOLKERS RESTORATION Restoring vintage things to last so the future can enjoy our past. |
Michael (WI) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Larrabee, WI Points: 815 |
If you run a search on the forum under my name or 904 wobble box you will see the lengthy disucssion on wobble boxes. I myself am looking for one also. Someone last fall indicated a wobble box off of a 720 chopper corn head would fit but I have not been able to confirm that. I do know the 409 and 390 boxes will interchange although the 390 has exterior improvements at the mounting ears.
Edited by Michael (WI) - 07 May 2012 at 8:24am |
YOU GUYS ARE WANTING SOME PICS SO LETS TRY THIS.
