39 B |
Wayne180d
Joined: 08 Dec 2015 Location: Gilman, Il Points: 5946 |
Topic: 39 BPosted: 10 Jan 2020 at 12:00pm |
I just picked up a 39 B and it has 6 bolt 15 inch rims on it and the bolts go all the way through and they have a nut and lock washer on them. They also put one castle nut on each rim. Never seen this before. I thought the 39 B's had the rim welded to the wheel center. Anybody have any ideas.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 10 Jan 2020 at 12:31pm |
Wyane,
Congrats on the new "B" I would like to see pictures and I know Bill Long would like to see his favorite tractor too! Regards, Chris
ryanschott
Posted: 10 Jan 2020 at 12:58pm |
I think they where riveted on and I’ve seen where people grind the rivers off and put through bolts so they can take on and off like a new rim
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 10 Jan 2020 at 1:22pm |
I believe that type of hub was on the prototype B tractors under serial #101. Who knows how much swapping of parts has gone on throughout the years. When I worked a Ford dealer in high school we were always working on 928N tractors. Tractor jockeys would bolt things together in in matter they could to get a running tractor that an unknowing yuppie would buy.
B26240
Posted: 10 Jan 2020 at 3:21pm |
I've been told both rivet on rims and bolt on rims are correct for 39 that the switch was made some time during the year. My 39 s/n 26240 had rivet on rims. On a slightly different subject I have seen where the threads in the hub were stripped and some one used nuts on longer bolts on the back side of the hub to hold the rims on.
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Posted: 10 Jan 2020 at 7:22pm |
I have B 22xxx with riveted hub to wheel.
