3-71 detroit any interest
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Topic: 3-71 detroit any interest
    Posted: 02 Jan 2011 at 8:49am
Know where their is a 3 cyl detroit with blower, that I think could be bought. Out of a crane, runs excellent. So complete power plant. Is it factory in anything (dozer)? Thanks Gary IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 8:50am
Also what is hp of it? Thanks
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 9:02am
I wonder if it would fit in my D-17D
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 10:20am
A HD7 early style used the 3-71, as well as Pettybone in their 1 1/2 yd loaders in early 50's.  is around 75 HP and a unit that was used to repower many other older gas engine machines.  seen pictures on here of farm use tractors repowered HD5 units also (source other member on here)
Edited by Coke-in-MN - 02 Jan 2011 at 10:23am
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 2:19pm
Have looked at several HD-5 conversions to the 3-71. Owners have told me they make an HD-5 a real pulling tractor. There are a number of them in the Red River Valley in ND and MN and have seen a few go at auction in Canada.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 2:44pm
Probably a little much for my OC46.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 3:27pm
A 3-71 must have more than 75hp as my 3-53 in my 230 Timberjack has 78, according to the service manual.  The 71 series have more power than the 53 in everything I have ever run (of course they are also a larger displacement).
macec3(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macec3(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 4:43pm
113 HP with N65 injectors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 5:35pm
Oliver Super 99, 990, and 990 Lugmatic used them. Post it on the Oliver boards and you will likely get some takers.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 6:36pm
I have heard you can figure 71 cu in and 30 h p per cyl in 71 series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 6:55pm
2-71 in a HD5 according to engine plate is 48 HP least in the early units , they use HV7 injectors
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 7:33pm
PM me a price....think I could shoe horn it in a WD45?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 1:09am
my HD5 had the 3-71, wonder if i could repower one of my pickups with one?
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 2:35am
Friend of mine put a 3-53 in a chevy pickup years ago.  It was great for mileage but it just lacked a little get up and go at higher speeds.  Said if he was going to do it again he would put a turbo on it.
You coluld tell who it was without any doubt when he came down the road too!
Edited by Amos - 03 Jan 2011 at 2:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 7:42am
As I have that extra 2-71 setting out back I keep thinking it needs to go into something. Idea was a WC would be a great conversion but need to get the WC first.
 Also thought of that in small pickup. but at 50 HP would lack a lot, might be like the 6.2 in 85 Chev PU
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 11:06am
Shameless, 71 series have been done, one guy has a turbo 4-71 silver in his 3+3 chevy C30.  It took a lot of work.  Lift the body, lower motor/tranny, lift the suspension/new custom rocker covers and oil pan all because the engine is just to damn tall.  Also he used an aluminum military block and it was still heavy as hell.  Stick to a 4-53 if you are going to do a pickup.  Still better have 4wd or you will get stuck on wet grass and winter roads would be a death trap.
JHanson907 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JHanson907 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 10:01pm
GaryIN:  Is this a motor you are selling?  If yes, how much and would you be willing to pull and pallet motor for shipping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 7:06am
Friend has it didn't know if it was worth the work getting it out. Will get details and price, and let you know. Thanks
This page was generated in 0.180 seconds.
