3500 to 3700 engine swap help |
Kevin210
Topic: 3500 to 3700 engine swap helpPosted: 07 Jun 2019 at 8:58pm |
OK guys I was hoping the fan pulley and the alternator on the 3500
would interchange to the 3700 but it appears they won't. There wasn't a fan or alternator on the 3700 when I got so I was hoping things would swap. So now I'm assuming I will need a fan and pulley and alternator for the 3700 to line things up for the belts. |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3665 |
Posted: 07 Jun 2019 at 9:18pm |
Yes the belts are wider on the newer series engine rightly so they are needed. Your assumptions are correct.
Kevin210
Posted: 09 Jun 2019 at 8:16pm |
Well today I did a lot of looking and figuring.
The exhaust manifold on the irrigation motor I bought is cracked in the middle section so I took the whole manifold off. I have a manifold for a 7045 I think it is that I bought a long time ago so I could use a schwitzer turbo instead of the air research but that didn't pan out either so I used the 210 manifold and made an adapter piece to use the schwitzer turbo. I used the manifold off the 210 engine which already had the schwitzer on it so I have the turbo on now and oil lines on which I also had to have made since the original oil lines would no longer work. I still have to get an alternator that will line up and probably a fan and fan pulley also to get things right on the front. Still have a lot to do but overall I think things are coming along ok. |
Kevin210
Posted: 09 Jun 2019 at 8:22pm |
OH yeah,might be helpful if someone with a 3700 engine could send me the number off of the alternator maybe make it easier for me to find one.
Thanks. |
Posted: 10 Jun 2019 at 6:55am |
3700 engine or not, the alternator is configured to the chassis the engine is installed in.
