3500 engine with 4.5 inch pistons |
Kevin210
Topic: 3500 engine with 4.5 inch pistonsPosted: 23 Jun 2024 at 9:15pm |
Grasping at straws here but would
any one happen to have a 426 engine with 4.5 inch pistons or sleeves in it sitting in the back corner of the shop. |
ACFarmer
Posted: 29 Jun 2024 at 11:53am |
I have one laying here.
Making a living farming with and working on Allis Equipment
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 649 |
Posted: 29 Jun 2024 at 1:15pm |
This question is just for my information. Does the block have to be machined to a larger sleeve. Im assuming the standard sleeves arent thick enough for the larger bore
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Posted: 29 Jun 2024 at 10:04pm |
I believe the largest diameter piston in the thinnest custom made sleeve is in the 4.400" diameter range. So yes, the block needs to be bored for 4.500".
