3500 engine with 4.5 inch pistons
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 3500 engine with 4.5 inch pistons
    Posted: 23 Jun 2024 at 9:15pm
Grasping at straws here but would
any one happen to have a 426 engine
with 4.5 inch pistons or sleeves in it
sitting in the back corner of the shop.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2024 at 11:53am
I have one laying here.
Making a living farming with and working on Allis Equipment
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2024 at 1:15pm
This question is just for my information. Does the block have to be machined to a larger sleeve. Im assuming the standard sleeves arent thick enough for the larger bore
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2024 at 10:04pm
I believe the largest diameter piston in the thinnest custom made sleeve is in the 4.400" diameter range. So yes, the block needs to be bored for 4.500".
This page was generated in 0.107 seconds.
