344 buda engine toruques
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: 344 buda engine toruques
    Posted: 13 Feb 2015 at 8:22pm
could i get the torque specs on the 344 buda in a hd 6.
head torques
rod bearing torques
and valve lash specs for intake and exhaust.
and i'm sure i'm missing something.
and i sure want to think everyone on my previous post you all don't know how much help you are to a young guy like me thats trying to carry on a tradition of running all allis chalmers on my farm.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2015 at 10:08pm
Fire order 1342
warmed up (160-185) valve lash Intake .016" and Exhaust  .020" .
 After that, they may be set cold at Intake .018" and Exhaust .022"
Mains;  Front, Intermediate and Rear main caps 3/4" nuts 210-230 lbs. ft.  Middle main cap, 5/8" nuts, 160-170 lbs. ft.
Rod cap nuts, 120-130 lbs. ft.
Cylinder sleeve flange standout .006" to .009" abovethe flat of surface of block.. and must not be more than.002" between adjacent cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 8:20am
that explains it all thanks alot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 11:44am
A picture is sometimes worth a thousand words... Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 6:24pm
It doesn't seem to be in the manual I have but a good caution on stud mounted anything. From Detroit Diesel and Mack Truck were notes in their manuals to verify the studs at bottom of threaded bores prior to tightening head retainer nuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 8:12pm
thanks again everyone!!!!
Kent
Fletcher Farms
Fletcher logging
