341 C.I. "No Bore" Engine Kit for 301 block
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Topic: 341 C.I. "No Bore" Engine Kit for 301 block
    Posted: 15 Jan 2013 at 12:21pm
e
Edited by O.P.S. Heads - 21 May 2015 at 10:47pm
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2013 at 4:07pm
How the hell are ya old friend??!!  Interesting, one of my buddies was in the shop Saturday asking if I'd help with a llss tractor.....and now you post this!! lol  Hope all is well your way.....I didn't see you or doc at G-ville, and what happened on Kinze's last pass???  I don't think I've ever heard a twin spin small block get under the chargers??
Slade
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2013 at 7:27pm
Good to hear from you too. Not sure on Kinze's. No breakage that I know of. I think a combination of the tough Gordyville dirt and Craig having to ride the brake that last 30 feet or so was more than the old girl could stand. Hope all is well down south. Be good!
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2013 at 10:34am
Mike... I still have the deere pistons that arem cut if you need them....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2013 at 11:53am
Also 2 complete blocks if you need rods
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2013 at 3:37pm
Interested in your setup, , sent an email
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2013 at 6:46pm
Robert,
Are you blocks complete? Crank, rods, cam, front cover, and engine plate? Are the the late model blocks with the crank driven oil pumps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2013 at 4:22pm
1 block is a early combine block 4 bolt crank cam drivin oil pump no head or back plate. 2 blocks are crank drivin oil pumps. 1 is complete minus inj. pump and back plate just stuck. the other is the one from my tractor block is broke, cam is broke, crank could be good and head should be good. all have front plates and timing covers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2013 at 1:28pm
e
Edited by O.P.S. Heads - 21 May 2015 at 10:48pm
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2013 at 10:05pm
Whats the compression ratio
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2013 at 9:58am
e
