3208 cat improved turbo recommendations ?
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Topic: 3208 cat improved turbo recommendations ?
    Posted: 22 Sep 2018 at 11:47am
  I have  neighbours with 3208 cat in a 2255 white.  What turbo would work good  on this engine  in  a hot farm, local brush pulling scenario,   but still  a stock engine.   a lot of cubic inches  to work with here.
Edited by Beirnesy - 22 Sep 2018 at 3:00pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 4:46pm
If you don't increase fuel delivery and RPM's you're wasting your time with a change in turbochargers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 8:03am
Your also wasting your time with a 3208! Terrible engines! The 3406 was a little bit better engine in that department. Not much, but a little better. I worked on a lot of 3208's in truck chassis', and I got one word for those engines: "duds".... Maybe they work better in Tractors? I dunno. They sure didn't work well in our trucks at work...  Thumbs Down
Steve@B&B
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 8:14am
I think the "Warpath" Massey and "Bad Kitty" Oliver are running 3208's.  Blocks anyway.  Doubt there is much if any stock to them.  Not sure what "Silver Bullet" has in it.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 8:49am
This 2255 white/cockshutt/oliver is originally naturally aspirated but buddy would like to put a turbo on it to wake it up,  He got it as a half built puller with 30.5 cut rubber on the back and tractor all striped down.  We have came across a Garrett GT4294 wastegated turbo off a 60 series Detroit that he will likely try out.  It is for local brush pulling . Its not going on the NTPA circuit. I apologize for putting NON ALLIS tractors on this forum aswell.
Edited by Beirnesy - 30 Sep 2018 at 8:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 8:49am
3406 was and remains the best engine Cat ever made, all too many older units overhauled two three even for the fourth time and still hammering out 450-600hp.
The 3208 is junk, a disposable bored cylinder block with minimal cylinder wall thickness where they IF overbored to correct egg shape or ring worn bores will get hot. Two rings per piston, when they wore out they were exchanged as all too many tried to rebuild they would NOT last, cat would supply New "Reman" engines where the used heads would go on a new block, saw this over my career many times. A turbo on any diesel will clean up smoke but will not deliver more fuel, delivering more fuel to an already at capacity engine just eats them up faster.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 6:08pm
AaronSEIA
The Masseys are running 640 Perkins V8's.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 4:37am
The 3406 is a 6 cylinder. The 3208 is a V-8. It's been a lot of years since I had any experience with the 3208, but IIRC, the 3208 replaced the 1100 (????)
The 3208 was the stock engine in a few farm tractors and some combines.
Admittedly the 3208 wasn't the best engine ever built, but if that's what the guy has, it's what he has to work with.
There are a few 3208 engines on the tractor pulling circuit, that seem to rum well. I have no idea about longevity.
Edited by WF owner - 01 Oct 2018 at 4:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:15am
Thanks for the clarification, Ed.  I know Masseys ran Perkins, not sure why I thought the pullers were using Cat engines.
AaronSEIA
