314d mower decks
Message Reverse Sort Order
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Topic: 314d mower decks
    Posted: 20 Feb 2022 at 7:24pm
I do believe the housing for the 42" deck used on a 6010 Broadmoor is the same shell with differences in the mule drive and belt tension system. There may be differences in center spindle pulley diameters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 7:21pm
Not exactly. They were made with Simplicity parts. There was no Simplicity equivalent to the 300/400 Series. The decks for the 6200 series may look similar but the spindles are different between the two and I believe there are other differences.
Jrbents View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrbents Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 7:02am
Are the AC 314d and the similar Simplicity decks the same pieces ??
