30wt VS 15W40 oil pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: 30wt VS 15W40 oil pressure
    Posted: 05 Nov 2016 at 11:01pm
Is it likely that you have higher hot oil pressure with 15W40 over straight 30wt? 15W40 is supposed to act like 40wt hot so that would make sense.Just wondered. I put 15W40 in my 220 last winter and used it for all fall work this year.It runs just under 60psi WOT and I could swear it use to only make 50 with the 30wt but,it's been about 6 years since it really got worked and I got CRS.
The 8070 is out of commission for the time being,ergo using the 220.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 11:11pm
Uh oh...another oil pressure thread! Batten down the hatches!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 12:07am
Not been my experience. 30 wt will carry a couple more pounds of hot oil pressure than 15W-40 does.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 6:28am
Years ago, I owned a delivery truck (IH 2155 w/ dt466) that did alot of slow idle with a pto, in the summer I ran 30w, in winter 15-40, it alway's showed higher pressure even in the hottest day's with the 30w that it did in the winter with 15-40.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 7:13am
I run 15W-40 diesel grade oil in every engine I own and when I change oil the first time in a tractor I buy the oil pressure almost always increases,of course i don't have any way to know what was running it when I bought the tractor.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 7:20am
I think we're all pretty safe now.the arrogant know it all, that caused all the havoc lately and took threads off topic and turned them into his own personal pi$$ing match was suspended and shut down last week.Thumbs Up thanks moderators.
Edited by ac45dave - 06 Nov 2016 at 7:27am
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 7:21am
2x LMAO
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 7:25am
i always found in my own experiences, straight weight oil to carry a little higher pressure than multi weight oils.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 7:51am
the straight weight might have a slightly higher pressure than the 15w40.  "Theoretically" they should be similar , but remember, the multiweight is a combination trying to solve multiple problems. The main advantage of a 10w30 or 15w40 is not the pressure when HOT, it is the advantage of thin oil when COLD to get the oil flowing quicker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 8:51am
That would have been my guess too.Kinda why I ask.I guess I'm okay with what it is but am a little puzzeled.
This page was generated in 0.111 seconds.
