30KW generator
Message Reverse Sort Order
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 30KW generator
    Posted: 13 Mar 2013 at 10:39am
Wireng for the 12 lead head should be standard. I would guess that to make it work when wired double delta they had to do something with the voltage regulator? Wiring diagram for standard heads is linked.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 10:13am
I'm in Florida for a couple more weeks. When I get home I can look in my electrical books and maybe find something.
Dusty
TexasGary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasGary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 2:40pm
  Hello Everyone,
I am new to the forum and have a question on a AC 30 KW generator with a D262 naturally asperated engine. I am trying to get 240 VAC 3 phase out of my 12 lead generator and have hooked up in a series delta configuration and  the leads are connected  as follows. 3 interconnects of 8 & 5, 6 & 9, and 4 & 7.   The lineout connections are 1 & 12, 2 & 10  and 3 & 11.  The generator works good as it was connected double delta getting single phase power out of it before.  I should have gotten 240VAC phase to phase unless the AC gensets can not be hooked up this way. Can anyone shed some light on this
Thanks in advance
Gary in Texas
